It is currently Sun Aug 17, 2025 5:26 pm
 Post subject: Aluminum Bending Slats?
PostPosted: Wed Jul 16, 2014 6:15 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Anyone out there using aluminum flashing for side bending with a heating blanket?
Pros, cons and opinions would be appreciated! Thanks!
Alex
PostPosted: Wed Jul 16, 2014 6:29 pm
First name: steve
Last Name: barbour
Country: U.S.
I use a heavier stainless steel slat on the bottom to help provide some support and use aluminum on the top side to give the blanket some protection. I like the aluminum because it rolls up and stores away easily. It was also a lot cheaper than the alternatives. You have to flatten it out a little after a bend, but not a big deal.
Kyle
PostPosted: Wed Jul 16, 2014 6:37 pm
I use aluminum. Pros are, easy to find and cut your own, and does not rust. Cons are, they do not flatten back out like spring steel slats and stains easily.
Chuck
PostPosted: Wed Jul 16, 2014 8:29 pm
First name: Tom
Last Name: West
State: Nova Scotia
Alex: Absolutely, the only thing I've ever used.
Tom
PostPosted: Wed Jul 16, 2014 8:38 pm
First name: Alex
Last Name: Kleon
City: Whitby
Tom
Thats good to know, Tom. You can get a lot of slats from a $25/50ft roll!
Alex
PostPosted: Wed Jul 16, 2014 9:29 pm
I am a little worried about gassing out of hot aluminum. I'm not sure why. Anybody else?
PostPosted: Wed Jul 16, 2014 10:22 pm
Last Name: Killin
They make camp stoves and cookware out of aluminum. I’d not be worried about the temperatures we are using.
Of course I have no actual scientific research to back that assumption up.
I've used flashing and it has worked. I wonder if I'm getting as much support with it as I would with a steel slat though.
PostPosted: Wed Jul 16, 2014 10:34 pm
I've always used blue tempered shim stock covered with foil. I don't like slats that deform and have to be straightened.
PostPosted: Thu Jul 17, 2014 7:13 am
First name: Tom
Last Name: West
State: Nova Scotia
Pat: I think the temps are much too low to worry about that. Zinc and galvanized metal can be a problem when welding but have never heard anything about aluminum.
Tom
PostPosted: Thu Jul 17, 2014 9:20 am
I use scraps of HPL for bending slats. After awhile they take a set, but being scraps they cost nothing and can be replaced.
Aluminum shouldn't pose a health risk at the temperatures wood bends at. Aluminum soda and beer cans would probably be more of a health risk, but again I think it's pretty small.
